refilling evaporator with gas & coolant bleeding
Colin H F
Post by Colin H F » Fri Oct 12, 2012 12:06 pm
Starting a new thread on my matrix issue in readiness for when my new [used] evaporator arrives. does anyone know any where or anyone who can re-gas the system for me once its ready. Preferably in the Liverpool area, Wheelquick don't do it. also I have seen the vids on coolant bleeding and it took three of them using the funnel system, is there a simpler way, other cars I have done in the past, you just keep topping up the radiator and header tank while using the bleed nipple. why doesn't the system just blow the air out once its hot and the pump is running. #-o #-o #-o
Driver+Passengers
Re: refilling evaporator with gas & coolant bleeding
Post by Driver+Passengers » Fri Oct 12, 2012 12:09 pm
Colin H F wrote:Starting a new thread on my matrix issue in readiness for when my new [used] evaporator arrives. does anyone know any where or anyone who can re-gas the system for me once its ready. Preferably in the Liverpool area, Wheelquick don't do it. also I have seen the vids on coolant bleeding and it took three of them using the funnel system, is there a simpler way, other cars I have done in the past, you just keep topping up the radiator and header tank while using the bleed nipple. why doesn't the system just blow the air out once its hot and the pump is running. #-o #-o #-o
If there's air in the cylinder head, the pump is trying to push the air /down/ from the top of the engine to somewhere near the level of the front axle before it comes back up again to the radiator, and then the degassing tank. I think. That's why you need to bleed from the head. Thereafter, there's the return from the radiator to the thermostat, hence the need to get it hot enough to purge that pipework. I think.
Image Image
Post by teenmal » Fri Oct 12, 2012 12:11 pm
That is exactly what it should do,once the thermostat opens,you should get a rush of air from the bleed hose.
Colin H F
Post by Colin H F » Fri Oct 12, 2012 12:17 pm
I see, ah well I'll just have to persevere with the well tried way once its all back together thanks guys
Post by haydn callow » Fri Oct 12, 2012 12:21 pm
the reason there are 3 peeps doing the bleeding vidio is just for demo.....2 peeps are plenty and I have done many on my own...Do not ignore the warnings about bleeding...the cylinder head is the high point in the system and being mid engined there are loads of coolant pipe runs.......get it wrong and a new cylinder head will cost you about £2000 fitted.
Colin H F
Post by Colin H F » Fri Oct 12, 2012 1:05 pm
Cheers Haydon you don't fancy a trip to Liverpool do you :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Post by teenmal » Fri Oct 12, 2012 1:32 pm
Hi Colin,
Sorry for my reply,just noticed that you have a 2000 petrol vehicle.
mikeWalsall
Post by mikeWalsall » Fri Oct 12, 2012 1:39 pm
Not a big fan of them .. but KwikFit do re-gas for around £50 ... if it don't work ..you don't pay..
Post by g8dhe » Fri Oct 12, 2012 1:58 pm
I thought the 2l petrol didn't have a bleed tube as such, the tube already runs back to the degassing tank I seem to recall, so it may bleed itself but you won't be able to apply the video method anyway.
Post by haydn callow » Fri Oct 12, 2012 2:02 pm
Ah, missed the 2 liter bit....Just refill as a normal vehicle.....no bleed tube
Colin H F
Post by Colin H F » Fri Oct 12, 2012 2:14 pm
teenmal wrote:Hi Colin,
just read all the coments thats good news then =D> =D> =D> =D> =D> =D>
Colin H F
Post by Colin H F » Fri Oct 12, 2012 2:18 pm
mikeWalsall wrote:Not a big fan of them .. but KwikFit do re-gas for around £50 ... if it don't work ..you don't pay..
thanks mike at least I now know it can be done when I'm ready it it OK to run without it be gased if I dont use the rear heater
mikeWalsall
Post by mikeWalsall » Fri Oct 12, 2012 2:37 pm
When the compressor is engaged the A/C system also uses oil in the refrigerant gas to lubricate the bearings etc: .. so do not turn the A/C on until it as been re gassed ..
The A/C engineers usually have all the relevant info stored in there computer .. but there maybe a specification label under your bonnet with the information similar to this ...
refrigeration (HFC 134A) and the oil viscosity (Nippon Desno grade eight)
Colin H F
Post by Colin H F » Fri Oct 12, 2012 4:01 pm
Just picked up a leaflet from my local "motor word" shop "regassing £35" phoned him up and he and he said give us a ring when your ready, result =D> =D> =D>
Colin H F
Just picked up a leaflet from my local "motor word" shop " AirCon regas £35" phoned him up and he and he said give us a ring when your ready, result =D> =D> =D>
