glowplug timer
madmacks3
glowplug timer
Post by madmacks3 » Thu Oct 11, 2012 10:40 pm
Hi Can anyone advise me about where the glowplug timer is located? Need to get bongo fixed before Monday15th Oct 12 Thanks,
Re: glowplug timer
Post by g8dhe » Thu Oct 11, 2012 11:11 pm
Its part of the ECU itself not a seperate module, the "timer" isn't a timer it measures the Rev's and temperature and controls the glowplugs as needed.
B2-04 is the relay itself controlled by the ECU (PCM box)
madmacks3
Re: glowplug timer
Post by madmacks3 » Fri Oct 12, 2012 9:41 pm
Hi Geoff, thank you for the info and hope that I can sort it out before long. Regards, Eileen
madmacks3
Re: glowplug timer
Post by madmacks3 » Mon Oct 15, 2012 10:25 pm
g8dhe wrote:Its part of the ECU itself not a seperate module, the "timer" isn't a timer it measures the Rev's and temperature and controls the glowplugs as needed.
Hi Thanks for the info, but I am struggling in trying to see the wiring diagram on the manuals on line as per earlier posts. I have tried everything and only end up with a green page with nothing on it at all. Can anyone either email me a diagram or at least tell me what I am doing wrong.
Thanks in anticipation, lol Eileen
Re: glowplug timer
Post by g8dhe » Mon Oct 15, 2012 11:07 pm
If you hit the web site in the last hour or so then try again ... Just had an argument with the server as it decided it didn't like its hard disk's, its back up and running now, otherwise see below.
I wonder what computer Operating System and Browser your running ? You will need Flash to display the diagrams, so if your running an iPad or latest versions of Android 4+ (Jelly Beans) on a tablet then your out of luck :-( Send complaints to Apple etc.
