here we go????????????????
Posted: Thu Oct 11, 2012 3:38 pm
by alan
Just cuse we at the end of the camping season think the bongo throwing it teddys out the windows
more wraning lights today so here the codes .
P114 engine room thermosenor-open
p0115 ect circuit fault
po400 ecr system malfaunction
p1228 waste gate
i do hope this isnt going to cost a amr an leg to fix an ideas
Re: here we go????????????????
Posted: Thu Oct 11, 2012 6:35 pm
by Driver+Passengers
Is the first one the engine bay temperature sensor - just around the handbrake should be a connector to the sensor which pushes through the center cowling above the engine. Check that's present and correct.
Have you removed and blocked off your EGR in the past, or is it still present?
Check the wastegate actuator on the turbo moves, maybe drive around with the passy seat up and have someone in the back watching the turbo, or something. You can probably lube the rod with something, but I don't know what.
Can't help much more than these few ideas.
Good Luck!
Matt.
Posted: Thu Oct 11, 2012 6:40 pm
by Northern Bongolow
fan switch or wires to it on the side of the block (drivers side) would be my first shot alan.
Posted: Thu Oct 11, 2012 10:25 pm
alan wrote:Just cuse we at the end of the camping season think the bongo throwing it teddys out the windows
p1228 waste gate
For the benefit of an ignorant old fuddy duddy like me, how did you obtain this data Alan?
Posted: Thu Oct 11, 2012 10:53 pm
by alan
mikeonb4c wrote:alan wrote:Just cuse we at the end of the camping season think the bongo throwing it teddys out the windows
p1228 waste gate
For the benefit of an ignorant old fuddy duddy like me, how did you obtain this data Alan?[/quo itoke it to a place in tauton to get the the info you know plug in thing but there didnt have any time to do the work os iam thinking have a look my slef with hlep from here an if not then it be down to my locsl grarge when his unit put back togther after a fire an flood
Posted: Thu Oct 11, 2012 10:58 pm
by alan
thank you all so far well be having a look this weekend.
ecr i beleve is still in place .
Posted: Thu Oct 11, 2012 11:38 pm
Thanks Alan. Another useful tip. I wonder if many of our ageing Bongos might benefit from an ECU diagnostic.
Posted: Fri Oct 12, 2012 2:11 pm
by alan
mikeonb4c wrote:Thanks Alan. Another useful tip. I wonder if many of our ageing Bongos might benefit from an ECU diagnostic.
think if you useing it to point you where to looks then yes but not so sure it pin points want wrong
Posted: Thu Nov 01, 2012 10:05 pm
by alan
Well i couldnt fine want was wrong with her(bongo) os ended up in the garage they sorted her and she back home were she belongs
