Fault with my manual heater control panel
philscotland
Post by philscotland » Mon Oct 08, 2012 1:27 pm
My 1995 2WD 2.5TD Bongo camper has a heater control panel that is very temperamental.
It is the old-style slider controls version, not the digital display.
Occasionally it blows at full speed, no matter where the blower dial is pointed, but more often than not, the blower does not work at all. Also, the switch for the rear ventilation sometimes lights up, but othertimes does not.
The air conditioning appears to work - I can hear the engine note change when I switch it on.
After printing off the various heating factsheets from the site, I have checked the fuses, wiring, resister pack and fan motor and they are all fine (hence why it works occasionally), so I am thinking that it must be the control panel blower dial that has a fault.
Any help would be greatly appreciated.
Phil
Re: Fault with my manual heater control panel
Post by g8dhe » Mon Oct 08, 2012 1:42 pm
Can you get at the plugs on the back of the control unit and check that they are fully in OK ?
lazyb5
Post by lazyb5 » Mon Oct 08, 2012 5:17 pm
When you say the fan motor is fine, have you had it apart and checked the carbon brushes
philscotland
Post by philscotland » Mon Oct 08, 2012 8:33 pm
Yes I've checked, unplugged and reconnected all the plugs to no avail unfortunately.
I haven't checked the brushes yet, partly because the blower does randomly work sometimes.
Anything else that I could check ?
Phil
Post by g8dhe » Mon Oct 08, 2012 8:56 pm
philscotland wrote:Occasionally it blows at full speed, no matter where the blower dial is pointed
Are you certain about the full speed bit ? Because that narrows the problem down a bit, if it really comes on full blast no matter what the setting then it suggests that the motor is not being fed via the resistor pack which is what varies the speed, which in turn suggests that it might be a broken wire making random contact to earth, or a problem within the actual resistor/fuse pack which you say you have checked - have you actually opened the resistor pack up an checked inside as per the factsheets ?
jaylee
Post by jaylee » Mon Oct 08, 2012 9:09 pm
philscotland wrote:Also, the switch for the rear ventilation sometimes lights up, but othertimes does not.
It won't if the front don't work, or isn't switched on.... :wink:
philscotland
Post by philscotland » Tue Oct 09, 2012 8:53 pm
Quick update.
I've been outside checking a few more things following the factsheets.
After supplying 12v directly to the fan connector block, nothing happens.
With the ignition on and heater switch on, the supply side of the connector block gets 12v.
It looks like the fan needs new brushes or motor windings, or worse case completely replaced.
Its zero degrees at the moment, so I don't fancy taking it apart tonight, but I'll check the wiring from the connector block to the fan housing and then remove the fan motor at the weekend to see if it can be repaired.
The fan however has definitely worked at full blast on a couple of occasions (I've only had the Bongo 1 week).
Oh - almost forgot - I noticed that the 30A PAL Heating fuse (17) had blown since when I last looked on Sunday.
I swapped it with a spare one and it hasn't blown after playing with the heater controls for 5 minutes or so.
Any idea why this might have blown ?
If anyone has any other suggestions, please let me know.
Phil
Post by g8dhe » Tue Oct 09, 2012 10:26 pm
The fuse only covers the fan itself so no other circuit should be involved. If you have the Ignition turned ON then the fuse is connected thru to the fan motor via the relay so if you have been playing about with the fan at any time with the ignition turned on then there is every chance it could blow whilst mucking around.
Post by Simon Jones » Wed Oct 10, 2012 12:22 am
Common problem is the drain hole in the centre of the scuttle below windscreen gets blocked so rain water overflows into the fan bearings. Remove the flat plastic 'funnel' that feeds air to the fan. With the ignition switched off, reach your hand inside the fan unit and try spinning the fan blades. It should turn quite freely and continue to spin for a second or so when you let go. If it does not spin smoothly, then your bearings need attention. The extra load of a stiff motor could be enough to blow the fuse. Be careful though: if you continue to use it with stiff bearings you stand a chance of knackering the resistor pack which has a habit of melting the solder joints when it gets overloaded.
philscotland
Post by philscotland » Wed Oct 10, 2012 12:27 pm
Thanks Simon
Yes the fan motor spins very easily by hand, so hopefully the bearings are ok.
I checked the drain holes at the weekend and they are clear - it's on my maintenance checks every few months now.
The main suspects now are probably the brushes or the wiring from the plug to the fan motor.
The previous owner fitted a leisure battery and what looks like a home made metal battery tray, which is very close to the wiring to the fan motor.
I'm going to dismantle everything at the weekend and hopefully get to the source of the problem.
The fact that I have heard the fan motor run a couple of times is confusing me - could this still happen if the brushes were worn - maybe it makes contact intermittently ?
Phil
lazyb5
Post by lazyb5 » Thu Oct 11, 2012 12:30 am
Hi Phil as you dismantle the fan the brushes are on a plate with springs behind to push onto the rotor. Mine had a seized bearing so plenty of grease and crocodile clips to keep the brushes in their home whilst you put the fan rotor back is the way to go. Don't forget one of the wife's tights over the square inlet to keep all the flies and debris away.
Post by Simon Jones » Thu Oct 11, 2012 1:13 pm
lazyb5 wrote:Don't forget one of the wife's tights over the square inlet to keep all the flies and debris away.
Ask her to take them off first though :wink:
philscotland
Post by philscotland » Sun Oct 14, 2012 7:05 pm
Found the culprit of my problem !
As suspected, my metal leisure battery tray was chafing the fan heater wiring.
Rewired and all working perfectly now :D
Thanks for everybody's help on this matter.
lazyb5
Post by lazyb5 » Sun Oct 14, 2012 8:47 pm
Good find hope you cleaned the fan whilst it was out :D
