Post
by helen&tony » Sun Oct 07, 2012 7:21 pm
From what you say, if you have to top up every week, you have a leak...no matter who checks it, it's there...IF all the hoses have been changed, then you may have one of the metal pipes corroded and pin- holed. What clips do you have on the hoses, and are they Mazda opriginal?...One MAJOR source of a hard- to- find leak is the waterpump...I had a leak that produced only a small loss, but it was there...I looked at the waterpump with a high-power torch, an inspection lamp and all sorts...BUT....knowing that the water pump was likely, I got a high-power focused beam on it, and there it was.....first thing in the morning before it had a chance to evaporate......so, the answer is, you have a leak, and persistent checking both hot and cold...engine running, and static....you WILL find it.
Tissue paper or talcum round the hose joints, and searching with a high-intensity focused beam will help. Tracer dye is not a lot of help unless you have a mains UV lamp, and then it REALLY works...If Haydn's firm haven't any, then e-bay sells it
Best of luck!
