New 17 inch rims
Moderator: Ian
Ian65
New 17 inch rims
Post by Ian65 » Sun Sep 30, 2012 1:05 pm
Hi All
This has probably been asked before but I've done a search and nothings clear.
I've just acquired a set of 17 inch Mazda alloys for the van with knackered 40 series tyres.
Going to get the refurbed and fit new rubber, but what size should I go for?
At the moment there's 195/80/15 on the front and 215/70/15 on the rear.
Can't make my mind up whether to go for 205/60/17 or 215/60/17 or do I need to put different sizes on front and back.
205/60/17 would make a 4mm smaller rolling radius on the back but 15mm smaller on the front.
205/65/17 would make 16mm bigger on the back and 5mm bigger on the front.
215/60/17 would make 8mm bigger on the back and 3mm smaller on the front.
215/65/17 would make 29mm bigger on the back and 18mm bigger on front.
Any help much appreciated as to what other bongo owners use
Re: New 17 inch rims
Post by francophile1947 » Sun Sep 30, 2012 4:00 pm
I fitted 225/55x17 on mine and the speedo was accurate 8)
weebrian
Post by weebrian » Sun Sep 30, 2012 5:26 pm
Got the same on mine but the speedo reads about 12% high ?
Colin H F
Post by Colin H F » Sun Sep 30, 2012 6:14 pm
215/60 R17 96H ALL ROUND ON MINE haven't checked the speedo
Return to “Pimp My Bongo”
