flashing glow plug lights
Glow plug liths flashing. Dove 7 miles then stop got. Back in bong then after. 1/2 mile light stated to flash ipull over. Wait 20 mins restated an lights have st oped any idea an is it safe to drive home
take it easy drive a bongo
Re: flashing glow plug lights
sounds like the glow plug relay may be faulty?also could be faults in glow plugs also.if it lights up on start again then goes out should be ok to drive.you could also put a test light from earth to top of glow plug when running if it does not light you def aint got power to plugs then u r ok to go/that gives you peace of mind
- Simon Jones
Glow plug light is a diagnostic indicator. Do a search on here & you will find a list of what the number of flashes signify.
thank you simon i have tryed athe search but with no luckSimon Jones wrote:Glow plug light is a diagnostic indicator. Do a search on here & you will find a list of what the number of flashes signify.
- maxheadroom
- maxheadroom
when searching more than one word type it like this; glow AND plug AND lights
