http://www.ebay.co.uk/itm/3-x-Beer-Bong ... 2049wt_924
Disclaimer: dont blame me if it melts in a big pile of goo
he's buying up the worlds stocks of things with bongo written on it as an investment.Titan1995 wrote:One wonders how you stumbled upon that item Simon?
Hence the £22 price tag.mantaJim wrote:To be fair it does say its a bongo 2.5
Titan1995 wrote:So what is the six potter non starting all about then?
Mine is also a not starter.....the FIP being in another country might be the reason. It is off for overhaul in Wales.
If no joy with all those parts, have a look at the crank pick up, passenger side, bottom of engine, when they fail they break down when hot and cause misfire then die altogether, and are usually last thing suspected as you still have a spark!mantaJim wrote:Titan1995 wrote:So what is the six potter non starting all about then?
It just cut out (about 4 miles form home after a 120 mile journey from Anglesey).
It started and ran, albeit very roughly with a bad misfire. Got it flatbedded home (evetually after a 3 hour wait) and now it refuses to start. I get fuel delivery and a spark but not sure the spark is strong enough so have just taken delivery (very fast turnaround BTW - many thanks to Ian) of a full set of HT leads, dizzy cap, rotor arm & coil and order igniter module. I do have some oil collection in the rearmost sparkplug tube on the drivers side though ..lots of posts about this and V6 non starting and misfiring i ngeneral.
Thanks Julian no joy unfortunately so will check crank pick up as you suggest321Away wrote:If no joy with all those parts, have a look at the crank pick up, passenger side, bottom of engine, when they fail they break down when hot and cause misfire then die altogether, and are usually last thing suspected as you still have a spark!mantaJim wrote:Titan1995 wrote:So what is the six potter non starting all about then?
Julian
