Radiator Needed
jsalcar
Radiator Needed
Post by jsalcar » Mon Sep 24, 2012 11:40 am
Hello everyone,
Advice needed again!!! My radiator is leaking from the top corner, drivers side. Do I need to replace the radiator or is it possible to fix? I read some posts and it seems that at the same time I change the radiator I need to "install" a new gen mazda stat - Thank you for all your help in advance.
Any suggestions where I can get/ buy radiator and stat, please?
oh! Another question. Would it be safe to drive the Bongo as soon as I keep coolant at right level?
Thanks again
Jorge
Viva el Bongo!
turbodave
Re: Radiator Needed
Post by turbodave » Mon Sep 24, 2012 8:41 pm
Hi ,happened to me in France..don't use radweld as it can damage other parts. This site and AVA leisure do parts. I don't know if K seal works on rads if you are desperate, but get it into a Bongo garage and get it done right! ..and the none Mazda rad is good and much cheaper!! ...also I would do all the pipes at the same time....As far as safe to drive goes, I drove carefully for about 40kms and all seemed well, but that is the problem SEEMED...you are never sure! Only drive it if its not leaking much and you have to.Dave
jsalcar
Re: Radiator Needed
Post by jsalcar » Mon Sep 24, 2012 10:10 pm
Thank you very much for your advice Dave.
Jorge
Viva el Bongo!
tim & angie
Re: Radiator Needed
Post by tim & angie » Mon Sep 24, 2012 10:41 pm
I bought a new rad earlier this year from euro car parts. Cheaper than Mazda and all running fine.
Tim
winchman
Re: Radiator Needed
Post by winchman » Tue Sep 25, 2012 7:02 am
Mine was the same
I just took it to Wheel Quick in Wigan
I had a new rad, thermostat ( might as well whilst its in bits)
New cam belt and fuel filter
£375 I was happy.
Its not a difficult job but to be honest I didnt want to have my first bleeding lesson five days before a hiloday in the Bongo so it was all about piece of mind.
Personally I would get the rad and stat done at the same time
jsalcar
Re: Radiator Needed
Post by jsalcar » Tue Sep 25, 2012 9:09 am
Thank you Winchman and Tim.
Jorge
Viva el Bongo!
MountainGoat
Re: Radiator Needed
Post by MountainGoat » Tue Sep 25, 2012 4:53 pm
Wheelquick is a great garage which I have used many times, well my sister lives only 4 miles away. But for you Jorge it could be a bit too fr. Why don't you give Bill at campercraft in Kirkcaldy a ring to see how much would charge for doing the job for you. http://campercraft.eu/default.aspx
Another possible Bongo garage near to you is Dairsie Autopoint in Fife, postcode KY15 4SR, tel: 01334 870271. or 2.
Tony
Re: Radiator Needed
Post by rita » Tue Sep 25, 2012 5:22 pm
