Immobiliser not active after battery change
eppiblue
Post by eppiblue » Sat Sep 22, 2012 12:24 pm
Hi, this week I replaced my starter and now my autowatch immobiliser doesn't seem to be working. I can start the van without the key fob and there is no flashing light. Can anyone advise?
'Vincent' - 1996 P reg - Green - 2.5 TD - 4WD - Likes: Diesel, Bitumen and Snow.
Re: Immobiliser not active after battery change
Post by g8dhe » Sat Sep 22, 2012 12:32 pm
There are several types, but a quick Google comes up with plenty of reports of various problems probably best to call the company direct as this thread suggests http://www.hiluxsurf.co.uk/showthread.php?t=75471 he had a good outcome it seems.
321Away
Post by 321Away » Sat Sep 22, 2012 3:04 pm
sounds like maybe you've blown the fuse supplying the immobliliser and its relays have defaulted to disarmed position, which itself is quite odd as Autowatch are not only Thatcahm/VSIB approved, amongst installing community they're reputed to be the best systems in the world? and although a lot of early and non rated systems are vulnerable to this type of attack, most modern ones arent, how old is the immobiliser?
Julian
eppiblue
Post by eppiblue » Sun Sep 23, 2012 11:45 am
seems to have started working again.... I will monitor and post back if it plays up again.
