ABS sensor
Davebo
ABS sensor
Post by Davebo » Wed Sep 19, 2012 9:55 am
Be gentle with me, I'm new. :oops:
I've got a few hits when searching but need some advice please ?
I need a new OSF sensor. Is it worth trying to source just the sensor or just replace the hub ? If so, how much labour time is a garage likely to charge me for stripping off a hub and replacing ?
Thanks in advance,
Dave.
MountainGoat
Re: ABS sensor
Post by MountainGoat » Wed Sep 19, 2012 10:18 am
I lost rear one after hitting a pothole last year and found out that new ABS sensors aren't exactly cheap at £184.00 each (May 2011). Bought one through Allan's garage in Plymouth (his wife Doone is a forum moderator). Had to wait a couple of weeks for one to arrive from Japan as he was out of stock. Probably about £60.00 (an hour or so's work) depending on the size of the garage and where you are located.
Tony
Re: ABS sensor
Post by Simon Jones » Wed Sep 19, 2012 1:05 pm
Have a search on the forum as this one has come up before. It's generally considered easier / cheaper to replace the complete hub as the sensors are easily damaged during replacement.
Re: ABS sensor
Post by Northern Bongolow » Wed Sep 19, 2012 9:38 pm
agree with simon on this one,if you can get the harness wire mounting bracket off without it snapping theres the sensor nut to remove (never managed this yet), the sensor will be stuck solid in the loop that it fits into. :oops: #-o.
swap the swivel for an abs swivel, these are different from no abs swivels,
MountainGoat
Re: ABS sensor
Post by MountainGoat » Thu Sep 20, 2012 2:21 pm
What I found when looking for a new replacement ABS sensor were a few for sale on ebay. But they were described as for the front wheels so it would seem to me that there are two different types of sensors, one for the front wheels and one for the back wheels.
Can anyone confirm this assumption.
Tony
Re: ABS sensor
Post by rita » Thu Sep 20, 2012 3:23 pm
MountainGoat wrote:What I found when looking for a new replacement ABS sensor were a few for sale on ebay. But they were described as for the front wheels so it would seem to me that there are two different types of sensors, one for the front wheels and one for the back wheels.
Tony
Hi,you will probably find that they are Normally Front and Rear,also Left and Right handed (ns/os)
Cheers.
Re: ABS sensor
Post by g8dhe » Thu Sep 20, 2012 4:38 pm
Lush projects indicates that each sensor has its own part number http://lushprojects.com/bongopartsmk2/c ... no=.html#5
