I have tried a couple of searches so sorry if the answer is already here somewhere?
I seem to remember somebody saying that it was possible to fit a (albeit small) caravanstore awning completely out of sight under the AFT or did I misunderstand a post about it being fixed under the AFT and hanging outside in its bag?
If it can park under the AFT, are walls available for that size?
Stealth Awning
Moderator: Muzorewa
Stealth Awning
- Simon Jones
Re: Stealth Awning
I think it was a Fiamma CaravanStore awning and the fixings were under the AFT which meant it was securely locked in place with the roof down. I think you'd struggle to get anything bigger than roller blind concealed under the AFT
Re: Stealth Awning
Ah, wishful thinking, I did see that post and it must be what I'm thinking about, thanks I will have a lookSimon Jones wrote:I think it was a Fiamma CaravanStore awning and the fixings were under the AFT which meant it was securely locked in place with the roof down. I think you'd struggle to get anything bigger than roller blind concealed under the AFT.
Re: Stealth Awning
Is this what you were thinking of? Nice and easy to fit and easily removable, and the awning is a lot cheaper also.
http://www.igmaynard.co.uk/bongo/forum/ ... 15#p541554
Re: Stealth Awning
Yes, that would be the one. What exactly is it listed as by Fiamma, is it the Lightweight awning?stuc wrote:Is this what you were thinking of? Nice and easy to fit and easily removable, and the awning is a lot cheaper also.
would I need to get brackets welded to the awning rail?
Re: Stealth Awning
Hi it is the caravanstore 255, as in the link.
http://www.fiammastore.com/Caravan-Awni ... ing-Canopy
Re: Stealth Awning
Cheers, will be looking out for onestuc wrote:Hi it is the caravanstore 255, as in the link.
