i just tried to change a flat and couldnt get one of the wheel nuts undone, the other four were REALLY tight. i got the van to a tyre fitters where they spent a while working very hard with various tools to remove said nut. anyway. it turns out i have nuts for steel wheels holding on my alloys. does anybody know a good place to source the correct nuts?
thanks
wheel nuts!
Re: wheel nuts!
Anywhere that sells alloy wheels - even Halfords if you're desperate
Re: wheel nuts!
I think you need a wheel bolt with an integrated shim so as not to damage the alloy (& causing cracks...).
When I went to replace my steels with alloys from a Mitsubishi (outlander) I got some bolts from a Toyota main dealer ( I was in a hurry and at the tyre fitters too!) - these were a direct fit and caused me no problems. The main dealer also took pity on me and threw in a set of locking nuts free (which meant I didnt clear him out of all his stock of bolts!). Chromes ones are best - I had no option but to go for the black ones -but I found they pitted quickly.
cheers,
Steve
cheers,
Steve
