So while I contemplate the detail of Ollys conversion, Im considering having leisure battery put in. Can internal lights, 12v socket be linked to leisure instead of main battery? Not huge use - recharging, cooler, etc.
What else do you run off your LB?!
Leisure battery
Re: Leisure battery
YES the answer to "what else " is everything apart from the original electrics which were in the van to start with
- mikeWalsall
Re: Leisure battery
Some modify the original system so that things like the lecky blinds and car radio are wired into the leisure battery so the key does not have to left in the ignition switch / accessory position to use them ..
Re: Leisure battery
Its normal to switch over the Radio and Cigarette lighters, Blinds, internal Lights etc from the original. The easiest way is to get a Willinton kit from Ebay, drop him an email with details and he will list a suitable kit - http://www.ebay.co.uk/sch/willinton/m.html
Re: Leisure battery
Work done! Went to Bill at CamperCraft...underseal and waxoiling...and the leisure battery!
