How to reset engine check light on 2004 2ltr Bongo
Can anyone tell me how to reset the engine check light on a 2004 2lt petrol Bongo , light has come on after full sevice and break pads changed , cam belt already changed at 80,000km . Thanks Droogle
- Simon Jones
Re: How to reset engine check light on 2004 2ltr Bongo
I dont believe there is a 'service due' indicator light fitted to the Bongo which would require resetting. Sound like a warning to indicate a fault. What does the symbol look like?
Thanks for the reply , its the orange engine symbol with the word check under neath , I checked another websites which said the indicator could come on at regular service intervals or when the cam belt needs replacing , as its just had a service I thought it ight just need a re set .
- Simon Jones
I think if its just come on as a result of a service you should raise it with whoever did the work as they may have accidentally disconnected something or not fitted something back correctly.
