leisure battery which one is best
goa55
Post by goa55 » Sun Sep 09, 2012 7:14 pm
i think i need a new leisure battery for the bongo which one should i get any recommendations ?
MountainGoat
Re: leisure battery which one is best
Post by MountainGoat » Mon Sep 10, 2012 12:38 pm
I've got one of these, works fine for me. http://www.tayna.co.uk/ELECSOL-100-Carb ... P5579.html
If you have the usual camping things transfered from the starter battery. Electric window blinds, radio,etc you have to make sure that nothing is draining the leisure battery (usual culprit is the radio but can be directly connected fridges) when your bongo is parked up unused as this problem can drain any battery.
Some people install a switch, being non technical I have a battery isolator fitted to my leisure battery which does the same job.http://www.redlinemaxed.co.uk/richbrook ... -128-p.asp You may find them cheaper on ebay.
Tony
Post by g8dhe » Mon Sep 10, 2012 5:02 pm
The largest AmpHr capacity that will fit your battery tray!
Post by mikeonb4c » Mon Sep 10, 2012 11:31 pm
I got a 135ah Energy Bull. It just squeezed in. Whether i'll ever get it out again is another matter ha ha.
mikexgough
Post by mikexgough » Tue Sep 11, 2012 6:45 pm
Energy Bull as Mike says....or the Platinum 110Ah ...fits a Willinton tray no problem and the terminals are well clear of the inner wing panel. I got a Platinum this year 4 days no leccy at the Bash fridge on all the time, lights,charging & TV use too..
As for others....can't comment ... as always... yer pays yer money
