Page 1 of 2
aerial
Posted: Fri Sep 07, 2012 3:16 pm
by lancyman
Hi all,
My bongo has had a broken aerial since I got it. It has the stump
of what I assume was the orignal aeiral, plus a screw shoved in it.
Can any reccomend a replacement aeiral, or how I can fix the old one?
Thanks.
Re: aerial
Posted: Fri Sep 07, 2012 3:58 pm
lancyman wrote:Hi all,
Thanks.
I remember Kirsty (no longer on here sadly) doing something cunning, involving (I think) screwing a whip aerial into the broken stump and producing a very acceptable result. Hopefully someone else can remember the details, or have a search for 'Kirsty' AND 'whip'
Ooooh matron
Re: aerial
Posted: Fri Sep 07, 2012 4:08 pm
by Northern Bongolow
the stump is made of brass, so very easy to drill /tap. just get a whip of the desired size and thread and screw it in.
chells has been like this for years.
if you take the swivel off to drill it etc dont loose the spring and ball bearing.
Re: aerial
Posted: Fri Sep 07, 2012 4:35 pm
by rita
You could try something like this,they come with adaptors.
http://www.ebay.co.uk/itm/CHROME-BLACK- ... 3cba0f603c
Re: aerial
Posted: Fri Sep 07, 2012 4:51 pm
Northern Bongolow wrote:the stump is made of brass, so very easy to drill /tap. just get a whip of the desired size and thread and screw it in.
Choose your words more carefully Ady, or Chell will give you a thick ear
Re: aerial
Posted: Fri Sep 07, 2012 4:54 pm
by Colin H F
yeah common occurrence mine came with about two inches left I had an old radio in the garage that did not work, so I took the telescopic section off hack sawed a slot at the end and squeezed it together so it would fit tightly into the existing stump and wrapped a piece of silver sticky back foil that lagers use round the join jobs a good un
Re: aerial
Posted: Fri Sep 07, 2012 5:06 pm
by Driver+Passengers
Tore mine in half at the car wash on Sunday. It's on the list.
Re: aerial
Posted: Fri Sep 07, 2012 5:09 pm
by briwy
Re: aerial
Posted: Fri Sep 07, 2012 5:16 pm
I noticed the comments on that thread about poor reception with new aerial. I can only say I get great reception with my standard aerial aqlmost all of the time even when it is retracted and laid flat. I hardly ever put it up, so less risk of breakage. Might help others, plus I can't imagine a whip type replacement giving poor reception. Nice job that Briwy
Re: aerial
Posted: Fri Sep 07, 2012 5:31 pm
by spud350
Strangley I've only just changed mine, and I mean in the last 15mins. You can buy original mazda one from the bongo shop for less than £40. It took 10 mins to change, and that's including getting the tools out of the shed.
Re: aerial
Posted: Fri Sep 07, 2012 5:58 pm
spud350 wrote:Strangley I've only just changed mine, and I mean in the last 15mins. You can buy original mazda one from the bongo shop for less than £40. It took 10 mins to change, and that's including getting the tools out of the shed.
...but make sure you don't lose the spring ball bearings when doing the job, I thought I read once?
Re: aerial
Posted: Fri Sep 07, 2012 6:02 pm
by Dr Fingers
Me too, must get it sorted. Radio keeps blurring out at critical moments, espec Radio 4
Can't live without Radio 4
Derek
Re: aerial
Posted: Fri Sep 07, 2012 7:47 pm
by lancyman
Thanks folks. Bought that one from eBay. For £4 worth a punt.
Re: aerial
Posted: Sat Sep 08, 2012 10:05 am
by cavey
Just going to hijack this thread briefly.....
My aerial keeps drooping and I've tried tightening the allen bolt as much as I'm comfortable with. I did remove the bolt and take the aerial off, to see if there was anything obviously wrong inside, but there was no spring or ball bearing. Is this my problem? We are talking about the roof mounted aerial here aren't we - as I have seen some on the front bumper?
Cheers,
Dave
Re: aerial
Posted: Sat Sep 08, 2012 10:22 am
by rita
Hi Dave,
There should be a ball and spring to make the aerial adjustable,if you want to make it rigid put a shake proof washer between the faces.
Cheers.
