aerial
lancyman
aerial
Post by lancyman » Fri Sep 07, 2012 3:16 pm
Hi all,
My bongo has had a broken aerial since I got it. It has the stump
of what I assume was the orignal aeiral, plus a screw shoved in it.
Can any reccomend a replacement aeiral, or how I can fix the old one?
Thanks.
Re: aerial
Post by mikeonb4c » Fri Sep 07, 2012 3:58 pm
lancyman wrote:Hi all,
Thanks.
I remember Kirsty (no longer on here sadly) doing something cunning, involving (I think) screwing a whip aerial into the broken stump and producing a very acceptable result. Hopefully someone else can remember the details, or have a search for 'Kirsty' AND 'whip'
Ooooh matron
:lol: :lol:
Re: aerial
Post by Northern Bongolow » Fri Sep 07, 2012 4:08 pm
the stump is made of brass, so very easy to drill /tap. just get a whip of the desired size and thread and screw it in.
chells has been like this for years.
if you take the swivel off to drill it etc dont loose the spring and ball bearing.
Re: aerial
Post by rita » Fri Sep 07, 2012 4:35 pm
You could try something like this,they come with adaptors.
http://www.ebay.co.uk/itm/CHROME-BLACK- ... 3cba0f603c
Re: aerial
Post by mikeonb4c » Fri Sep 07, 2012 4:51 pm
Northern Bongolow wrote:the stump is made of brass, so very easy to drill /tap. just get a whip of the desired size and thread and screw it in.
Choose your words more carefully Ady, or Chell will give you a thick ear :lol: :lol: :lol:
Colin H F
Re: aerial
Post by Colin H F » Fri Sep 07, 2012 4:54 pm
yeah common occurrence mine came with about two inches left I had an old radio in the garage that did not work, so I took the telescopic section off hack sawed a slot at the end and squeezed it together so it would fit tightly into the existing stump and wrapped a piece of silver sticky back foil that lagers use round the join jobs a good un
Driver+Passengers
Re: aerial
Post by Driver+Passengers » Fri Sep 07, 2012 5:06 pm
Tore mine in half at the car wash on Sunday. It's on the list.
Image Image
briwy
Re: aerial
Post by briwy » Fri Sep 07, 2012 5:09 pm
Re: aerial
Post by mikeonb4c » Fri Sep 07, 2012 5:16 pm
I noticed the comments on that thread about poor reception with new aerial. I can only say I get great reception with my standard aerial aqlmost all of the time even when it is retracted and laid flat. I hardly ever put it up, so less risk of breakage. Might help others, plus I can't imagine a whip type replacement giving poor reception. Nice job that Briwy =D>
spud350
Re: aerial
Post by spud350 » Fri Sep 07, 2012 5:31 pm
Strangley I've only just changed mine, and I mean in the last 15mins. You can buy original mazda one from the bongo shop for less than £40. It took 10 mins to change, and that's including getting the tools out of the shed.
Re: aerial
Post by mikeonb4c » Fri Sep 07, 2012 5:58 pm
spud350 wrote:Strangley I've only just changed mine, and I mean in the last 15mins. You can buy original mazda one from the bongo shop for less than £40. It took 10 mins to change, and that's including getting the tools out of the shed.
...but make sure you don't lose the spring ball bearings when doing the job, I thought I read once? :?
Dr Fingers
Re: aerial
Post by Dr Fingers » Fri Sep 07, 2012 6:02 pm
Me too, must get it sorted. Radio keeps blurring out at critical moments, espec Radio 4 :shock: :shock:
Can't live without Radio 4 :D
Derek
lancyman
Re: aerial
Post by lancyman » Fri Sep 07, 2012 7:47 pm
Thanks folks. Bought that one from eBay. For £4 worth a punt.
cavey
Re: aerial
Post by cavey » Sat Sep 08, 2012 10:05 am
mikeonb4c wrote: ...but make sure you don't lose the spring ball bearings when doing the job, I thought I read once? :?
Just going to hijack this thread briefly.....
My aerial keeps drooping and I've tried tightening the allen bolt as much as I'm comfortable with. I did remove the bolt and take the aerial off, to see if there was anything obviously wrong inside, but there was no spring or ball bearing. Is this my problem? We are talking about the roof mounted aerial here aren't we - as I have seen some on the front bumper?
Cheers,
Dave
Re: aerial
Post by rita » Sat Sep 08, 2012 10:22 am
Hi Dave,
There should be a ball and spring to make the aerial adjustable,if you want to make it rigid put a shake proof washer between the faces.
Cheers.
