P-Med wrote:...
Ah yes, Diplomat, you are quire right that that listening loud for long periods (or extremely loud for even short periods) of time can cause hearing damage. However, hearing damage is usually caused by frequencies in the 1kHz to 4kHz range, not by low frequencies. Particularly bad are sound systems that are turned up too loud and start clipping, causing lots of unwanted energy in this frequency band. By having a capable sub, you can take the bass out of the mid-range drivers, which means they can handle more power without distorting. Also,
Basically, loud bass doesn't really damage your ears, as our ears are less sensitive to bass - just Google: 'curve of equal loudness'
Interesting points.
My tinnitus has been with me since before I used NATO style headphones
http://www.c3headsets.com/products/head ... 62-headset to listen to Morse for long periods (filtered to peak at 800 Hz), before I went to Pink Floyd Concerts where the audio was on the threshold of discomfort but beautifully undistorted and long before I started going to T and T Carnival where the bass from the massive megawatt sound trucks shakes your innards as well as being still loud in the next town. I've heard this one three miles away.
http://www.youtube.com/watch?v=jePJOKmc ... re=related.
Notting Hill on Monday was tame in comparison, I don't think the police in the helicopter could hear the music.
http://www.youtube.com/watch?v=wENSNuWwO64.
I perceive a constant frequency very similar to the !5625 Hz TV timebase frequency which at my age I certainly couldn't hear normally. Luckily I can notch it out mentally a lot of the time. It's right across my head equally rather than one ear or the other.
What I do suffer more is loss of higher frequencies so I need more treble generally.
Recently an unwelcome development has been a crackling sound in one ear which is triggered by incoming sounds. Strangely it often clears under noisy conditions such as my visit to Notting Hill.
Naturally I blame noisy duplicating machines at work for my hearing troubles rather than music or radiocomunications.
I think I need super tweeters rather than a subwoofer. Luckily they would take up far less of the valuable space in the Bongo!
Frank
