Gearbox oil seal required.URGENT.
Amybongo
Post by Amybongo » Fri Aug 31, 2012 3:19 pm
My Bongo is off the road in need of a gearbox oil seal. We have one on order but it could be late September before it arrives. We were due to go on holiday to France on the 14th.
Can anyone help with the supply of the seal or have any idea where I can get one next week.
Re: Gearbox oil seal required.URGENT.
Post by francophile1947 » Fri Aug 31, 2012 3:28 pm
If you out your location in your profile, we may be able to suggest someone local to you :D
Amybongo
Post by Amybongo » Fri Aug 31, 2012 3:50 pm
Based near Bradford but willing to pay postage or collect.
The seal is the one in front of the gearbox, behind the torque converter
Post by Northern Bongolow » Fri Aug 31, 2012 4:07 pm
if you can get the old one out and measure it or get the spec from somewhere, these guys are good.
http://www.onlinebearings.co.uk/.
they do all types of seals too.
Amybongo
Post by Amybongo » Fri Aug 31, 2012 4:15 pm
Thanks I'll try them.
I am not able to measure it until the gearbox is out next week.
Does anyone have the dimensions ? [Oil seal at the front of the gearbox behind the torque converter]
Post by Northern Bongolow » Fri Aug 31, 2012 4:25 pm
you could at a push wait till its out then measure, these guys are quick to send.
have you tried ava leisure or allans at plymouth, or julian at 321 away. they may have one sat on the shelf, or have the spec.
Post by teenmal » Fri Aug 31, 2012 5:22 pm
Do you mean seal part number BV3519241,if so this might help re size/profile..
http://www.rockauto.com/catalog/moreinfo.php?pk=1838452
Amybongo
Post by Amybongo » Fri Aug 31, 2012 5:44 pm
We don't know the part number yet. Where did you get this number from.
I understand this gearbox is a Jatco R4A EL and may be the same as a Nissan gearbox. If so Nissan may have a seal. Can anyone confirm this ?
mikeWalsall
Post by mikeWalsall » Fri Aug 31, 2012 6:33 pm
A full parts list /exploded diagrams of the autobox is in the members fact sheet area .. you could try www.automaticchoice.com for the seal(s)
Quote ....
Earlier versions of the Mazda Bongo and Ford Freda use a Nissan automatic gear
box, code number RE4.
This document is a scan of a product catalogue supplied by a component supplier
called Automatic Choice. It lists all the components that can be found within the
RE4 automatic gear box.
Their website can be found at www.automaticchoice.com
Post by teenmal » Fri Aug 31, 2012 6:37 pm
Amybongo wrote:My Bongo is off the road in need of a gearbox oil seal. We have one on order but it could be late September before it arrives. We were due to go on holiday to France on the 14th.
This seal is in fact compatible with some Nissan boxes ,what seal have you ordered,do you have the order details.
Cheers.
Post by Northern Bongolow » Fri Aug 31, 2012 11:52 pm
have a look at this thread. the comment by roofraisers (nigel) may help.
http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=57562
maxheadroom
Post by maxheadroom » Sat Sep 01, 2012 8:32 am
Keep the Faith
Amybongo
Post by Amybongo » Sat Sep 01, 2012 10:03 am
Thank you for all the help and suggestions.
Part number BV3519241 may well be the right part number [after checking the diagrams.]
Does anyone have one ?
Post by rita » Sat Sep 01, 2012 11:39 am
It would be worthwhile giving... Alacrity a shout,he is an auto box specialist with his own business,and a very nice person.
http://www.autogearboxes.co.uk
Good luck
Amybongo
Post by Amybongo » Mon Sep 03, 2012 7:41 am
Thanks, just pm'd him and will be speaking to his company 3rd Sept. Hope he can help.
