Air conditioning squeal?
terryhill
Post by terryhill » Sun Aug 19, 2012 5:56 pm
Given the sweltering heat over the past few days, I have been having the air con. Today however when put on the air con it makes a high pitched squealing noise. Anyone any theories what it could be?
Many thanks
Re: Air conditioning squeal?
Post by Northern Bongolow » Sun Aug 19, 2012 6:08 pm
check the tension of the belt and the belt itself. or clean the pulleys, if its not been used for a while it could be covered in road crud or alternator belt dust, try a quick squirt with belt cleaner or wd or similar.
Post by teenmal » Sun Aug 19, 2012 6:12 pm
Hi it could be the belt/jockey pulley or the compressor bearing.Or even the radiator fan motor bearing
Cheers.
wonkanoby
Post by wonkanoby » Sun Aug 19, 2012 8:03 pm
mine was the bearing on the pulley that tightens the belt
mazda got me a kit replaced its bearing
