Post
by Simon Jones » Wed Jul 19, 2006 7:09 pm
The light will come on briefly when you start up - thats normal. Unless it stays on for a lot longer then I dont think you have much to worry about. I changed my fuel filter the other week - not a huge job, but messy unless you have the knack. The sensor is just a float which I guess goes up if there is water in the filter. You could remove the sensor wire, undo the filter, drain it off & replace, but if you were going to that much effort, you would be better top replace filter as well.
IMHO - unless it is staying on much longer than before, you should be ok for now.
