ns window goes down not up
terk
Post by terk » Thu Jul 19, 2012 7:15 pm
Hi slowly going mad...window went down...odered s/h switch as oldone was was melted inside...fitted new, window goes down not up
so took all to bits checked motor works both ways... check for broken wires on u bend all good....is there anything else that could be causing the problem
iam assured that the switched worked went sent to me. reluctant to take new one to bits yet..
cheers for any help
cavey
Re: ns window goes down not up
Post by cavey » Thu Jul 19, 2012 7:18 pm
From my experience - double check the u-bend.
perros huevos
Post by perros huevos » Thu Jul 19, 2012 7:28 pm
hi if there is only 2 wires going to the motor then it can only be your switch which is faulty
chris
Post by g8dhe » Thu Jul 19, 2012 9:01 pm
Sounds like you have reversed the two connections to the motor whilst testing perhaps ?
Diplomat
Post by Diplomat » Thu Jul 19, 2012 10:59 pm
Make sure that when you fit the switch rocker and lever assembly onto the actual switch slider underneath it that the slider is in the centre (off) position. The lever must then mate with it exactly otherwise it will only slide the actual electrical part of the switch one way and not bring it back to the centre when the rocker part is released.
Hope that makes sense.
Frank
They flew, I took up naturism
jaylee
Post by jaylee » Fri Jul 20, 2012 12:50 am
terk wrote:Hi slowly going mad...window went down...odered s/h switch as oldone was was melted inside...fitted new, window goes down not up
cheers for any help
Hi, did you work out why your old switch "melted inside"?? Possibly due to a short in the door loom?
You said you checked the U bend in the loom.. (Or the V i call it.) :wink: Did you also check where the loom goes into the body/wing through the rubber grommet? I've known wires break off in there too.. :idea:
terk
Post by terk » Fri Jul 20, 2012 9:27 am
contacts where still good but one of the plastic plungers had melted down which must have been on the up side as down still worked.it had been intermittent to get it go up
hence s/h switch purchase will check loom again
cheers all
perros huevos
Post by perros huevos » Fri Jul 20, 2012 5:53 pm
hi if its the drivers side window then it cant be a broken wire otherwise it would not go down so it can only be your switch.did the window go up slowly when it was working? if so then this is what caused your original switch to get hot, maybe the mechanisam needs lubing or the runners need spraying with dry silicone spray
chris
Post by g8dhe » Fri Jul 20, 2012 6:31 pm
The circuit for the windows is here (1997 version);
The motors are simple DC motors, the direction they run depends on the polarity applied, the switch circuit simply reverses the connections. So if it now runs in the wrong direction either the power to the module connections have been reversed or the motor connections have been reversed.
The only other possibility that comes to mind is that they have reversed the connections between different years in/by error/mistake, which year is your vehicle ?
perros huevos
Post by perros huevos » Fri Jul 20, 2012 8:15 pm
doh!! just read subject & its the passenger side, which switch have you changed the passenger? if so then the fault lies with the switch on the drivers side
chris
jaylee
Post by jaylee » Sat Jul 21, 2012 12:11 am
Or possibly the window up loom wire in the DRIVERS door..?!! :idea:
perros huevos
Post by perros huevos » Sat Jul 21, 2012 12:19 am
the window up wire in the drivers door supplies the negative for the window down in the passenger door, both wires that run from drivers door switch to the passenger door switch are 12v negative at rest if one of these wires were broke it wouldnt go down or up but he says it goes down so cant be broken wire
jaylee
Post by jaylee » Sat Jul 21, 2012 12:26 am
Trust me on this 8) I have a winder module fitted to mine which had a dodgy connection in the drivers door.. :oops: Both passenger & drivers passenger button for the passy window drove it down.. But not up until i fixed the connection! 8) 95 tintop.
terk
Post by terk » Sat Jul 21, 2012 7:51 pm
95 is the year
cheers
Post by g8dhe » Sun Jul 22, 2012 3:26 pm
Which switch had burnt out and has been replaced, the Passenger or Drivers door switch ?
Does the reversal happen on both switches or only from one door if so which one?
