Reversing beep
TerryG
Reversing beep
Post by TerryG » Thu Jul 19, 2012 4:13 pm
While nosing around trying to find out why my reverse gear beep and the beep from my aftermarket reversing sensors had simultaneously stopped working, I discovered that the sensor control unit had become dislodged and was dangling below the rear light cluster, where it had been treated to a good soaking which presumably what has caused the failure. Logic tells me I should try the fuse before anything else. Does anyone happen to know which is the relevant fuse?
'Enjoy every sandwich'
Re: Reversing beep
Post by teenmal » Thu Jul 19, 2012 5:49 pm
Hi are the reversing lights illuminating when reverse is selected.
The sensor control unit it usually stowed in the o/s/r inside panel.(under the tray)
Cheers.
Re: Reversing beep
Post by g8dhe » Thu Jul 19, 2012 6:03 pm
If its the Factory fitted reversing sensors then the fuse would be;
but as its a 3rd party add-on then anybodies guess!
