Flip down screen
Moderator: Ian
rhenry
Flip down screen
Post by rhenry » Fri Jun 29, 2012 6:37 am
Hi all
I have a single din stereo with small screen DVD player with video and audio output. I would like to fit a flip down monitor to connect it too maybe on roof between driver and passenger so we could watch movies on big screen from back. Anyone done this and any pics or ideas welcome.
MountainGoat
Re: Flip down screen
Post by MountainGoat » Fri Jun 29, 2012 11:58 am
Quite a few have done what you want to do. Have a look through these posts which are found in the archives.
Tony
http://www.igmaynard.co.uk/bongo/forum/ ... mit=Search
turbodave
Post by turbodave » Sat Jun 30, 2012 10:22 am
Hi, I have done this..I will post pics when I have a minute. Basically got a flip down bracket (£10), drilled through the roof into the forward section of the AFT (under metal box layer) , got a thin lcd (19 inch) with outputs that come out parallel to the back of the tv. I finally put in a hook at the top end of the telly in the roof to add extra support to the bracket whilst the van is in motion (connect tv to hook via chain, tie or string. So far so good! Audio can be improved if you use a 3.5 mm jack lead and use the radio system (if you have that function). Dave
rhenry
Post by rhenry » Sun Jul 01, 2012 4:11 pm
Dave that sounds great would be really interested to see pics when you get chance.
thanks
Richard
Return to “Pimp My Bongo”
