Window and mirror electrics
kingbillybongo
Post by kingbillybongo » Wed Jun 20, 2012 7:52 pm
When drivers door is shut all working fine,but when drivers door is open,only passengers side mirror works from drivers side.i know about the wiring loom problem from door to wing,but would it be more than one wire broken or is there another common fault,I.e.where do I look first and what to do about it?
Many thanks cam.
[color=#0000BF]billybongofreedom[/color]
Re: Window and mirror electrics
Post by Muzorewa » Wed Jun 20, 2012 8:22 pm
Loom for sure, probably not where it goes through the grommets but at the bottom of the "U" as it's distorted onto the cable clamp on the edge of the door :wink:
You'll have to cut the outer sheath away and hopefully the problem will then be self-evident.
cavey
Post by cavey » Wed Jun 20, 2012 8:48 pm
Muzorewa wrote:Loom for sure, probably not where it goes through the grommets but at the bottom of the "U" as it's distorted onto the cable clamp on the edge of the door :wink:
What he said. =D>
I had a problem with the passenger window not working from the passenger door switch, but fine from the driver's. There was a break at the bottom of the U on the passenger door loom.
kingbillybongo
Post by kingbillybongo » Wed Jun 20, 2012 9:16 pm
Thanks guys,will have to have a look,could be more than one wire then?
cavey
Post by cavey » Wed Jun 20, 2012 9:39 pm
To quote Hong Kong Phooey...."Could be!"
