That's how long I got out of the ones fitted to my Bongo earlier this year before they started knocking.
So who's currently supplying the best quality front drop links? Are the Blueprint ones from the club shop worth the money?
what about proper Mazda genuine parts from a Mazda dealer, that's what they fitted when it was built in Japan...wonder how did the original ones lastSimon B wrote:.............that'll last for longer than 1500 miles.![]()
At £40.00 Each it looks a good buy,how much are the gen mazda ones.Northern Bongolow wrote:ian at the bongo shop has several options available. you can select the GOOD ONES or the budget ones. ask for the good ones, these are half the price of the gen mazda ones.
if the droplinks are not lasting you may have other problems that are causing them to go early, like duff shockers, or worn/snapped antirollbar bushes/brackets etc.
ARB bushes were done at the same time and I assume the shocks are OK.if the droplinks are not lasting you may have other problems that are causing them to go early, like duff shockers, or worn/snapped antirollbar bushes/brackets etc
You never know .......Simon B wrote:ARB bushes were done at the same time and I assume the shocks are OK.if the droplinks are not lasting you may have other problems that are causing them to go early, like duff shockers, or worn/snapped antirollbar bushes/brackets etc
Read about using Vectra ones before but a Bongo weighs a fair bit more than a Vectra, so didn't seem like a good idea!
Wasn't aware you could get drop links from Mazda dealers, would be the ideal solution but at £90 each I think the cost would be prohibitive.
Looks like the ones from the club shop are favourite so far.
Any more suggestions?
