A QUESTION ON ACCESS
tboy
Post by tboy » Mon Jun 18, 2012 5:39 pm
Inside the Bongo you have your engine L & R access pannels. On the rear of the cowling is a plate held by 10 bolts or so.
Is this an upper access to the rear of the engine?
Re: A QUESTION ON ACCESS
Post by g8dhe » Mon Jun 18, 2012 5:59 pm
Do you mean the part 53-250C http://lushprojects.com/bongopartsmk2/c ... mgno=.html
Edit:Oops swapped the numbers try again!
tboy
Post by tboy » Mon Jun 18, 2012 6:20 pm
Cant see that number on the diagram! On the rear of the engine cover between the two front seats the panel is covered by carpet but has a number of bolt heads visible,
Post by teenmal » Mon Jun 18, 2012 6:34 pm
Hi,as you said,its the access panel to the rear of the head/core plugs etc..
tboy
Post by tboy » Mon Jun 18, 2012 6:44 pm
thanks.Sorted
