V6 crank case breather
westonwarrior
Post by westonwarrior » Sun Jun 17, 2012 12:53 pm
Or engine breather ? what ever its called
I would like to check this so can some one give me an idiots guide as to where to check please.
Re: V6 crank case breather
Post by g8dhe » Sun Jun 17, 2012 12:56 pm
Under the drivers seat, top left hand corner, it just pulls out from the hole no need to undo anything, then you can pull it off the hose and check it moves ok under pressure by just blowing into it.
westonwarrior
Post by westonwarrior » Sun Jun 17, 2012 1:11 pm
I will take a look
Post by g8dhe » Sun Jun 17, 2012 1:18 pm
I may have a picture, I'll have a dig and see but on the mobile at the moment!
westonwarrior
Post by westonwarrior » Sun Jun 17, 2012 1:21 pm
that would help me lol thanks again
mikeWalsall
Post by mikeWalsall » Sun Jun 17, 2012 1:22 pm
Part number 13-890 and any part listed as PCV (Positive Crankcase Ventilation) should be clean and clear ..
http://lushprojects.com/bongopartsmk2/c ... o=.html#28
Post by g8dhe » Sun Jun 17, 2012 1:27 pm
Yup just to the left and up of the lefthand spark plug, click for large image;
westonwarrior
Post by westonwarrior » Sun Jun 17, 2012 1:29 pm
Great thats brilliant
Post by Doone » Sun Jun 17, 2012 9:01 pm
With the engine running, you should be able to feel it 'ticking' if you rest your fingers on it.
mikexgough
Post by mikexgough » Sun Jun 17, 2012 9:16 pm
On older and little used vehicles sometimes the breather hoses get "hard" and also any "oil" vapour can coat the bore of the pipes and joint ends..... I blow them out with an airline after a gentle poke with a wire coat hanger....usually shifts any crud before I blow through.... Like Lorna says should feel a pulse...if not clean it out
