Best awning for mushroom roof?
Moderator: Muzorewa
billybadger
Post by billybadger » Fri Jun 15, 2012 11:22 am
Can anyone recommend a particular type? We're looking at the Traveller Annexe 1 or 3 at the moment. Are there any others that anyone would recommend? Would like to investigate all of the options? It needs to be attached to a Bongo with a Mushroom roof. Thanks!
Re: Best awning for mushroom roof?
Post by Ian » Fri Jun 15, 2012 12:55 pm
Does the mushroom roof version still retain the drainage channel?
mikeWalsall
Post by mikeWalsall » Fri Jun 15, 2012 1:54 pm
Yes ...
The rubber lip of the roof seal is about 1.25" (32mm) away from the rain gutter ..
Post by Ian » Fri Jun 15, 2012 4:27 pm
So will it take a figure of 8 channel? If so, then any Royal Traveller/Outdoor Revolution or Oase drive away awning will fit.
billybadger
Post by billybadger » Fri Jun 15, 2012 7:51 pm
Cheers chaps. Will probably get either a traveller annexe 1 or 3 then. Off camping for a week next week, and figured that in this weather an awning is a must!
Furydav
Post by Furydav » Mon Dec 17, 2012 6:54 pm
I'm interested, did you go for the traveller annex and if so how did it perform , how easy to assemble , take down and store etc also what is it like as a shelter ? ta
