diagram or photo
Posted: Thu Jun 14, 2012 2:58 pm
by tboy
is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
Or on the passenger side below the alternator is a component with a pully on the front,but on mine it does not seem to be connected?
Re: diagram or photo
Posted: Thu Jun 14, 2012 3:11 pm
by 321Away
aircon compressor
julian
Posted: Thu Jun 14, 2012 3:14 pm
by tboy
321Away wrote:aircon compressor
julian
should there be a belt attached to the pully?
Posted: Thu Jun 14, 2012 3:17 pm
You can find all the mechanical diagrams here select you version of the vehicle etc. first;
http://www.lushprojects.com/bongopartsmk2/
and the wiring diagrams for 1995 thru to 1999, but not post 2000 here;
Check out the Help pages and the Color codes as well!
Posted: Thu Jun 14, 2012 3:18 pm
by 321Away
yes, you should have 2 belts on the alternator, running around bottom (crank) pulley,water pump and alternator, in front of that shoul be a single belt running around (same)bottom pulley, then tensioner and aircon compressor
Julian
Posted: Thu Jun 14, 2012 3:27 pm
Posted: Thu Jun 14, 2012 5:12 pm
by dave_aber
tboy wrote:is there somewhere within the site i can find a photo or diagram of 2.5 tD engine.Mainly naming the components?
Have a look
here on the wiki.
