tdc sensor V6
joca
tdc sensor V6
Post by joca » Mon Jun 11, 2012 2:09 pm
Hi all, Can any of you tell me the were to find the TDC sensor is on a2000 2500 V6 is located. Thanks in advance. John.
Re: tdc sensor
Post by rita » Mon Jun 11, 2012 2:52 pm
Hi,do you mean the crankshaft position sensor?
321Away
Re: tdc sensor
Post by 321Away » Mon Jun 11, 2012 3:09 pm
drop the tray under the engine, climb under tand its located at the front bottom of the engine, held in with a 10mm iirc
Julian
Re: tdc sensor
Post by g8dhe » Mon Jun 11, 2012 4:40 pm
I think you'll find its 18-230 on this diagram;
http://lushprojects.com/bongopartsmk2/c ... no=.html#2
and that referees to 14-100 on this one;
Re: tdc sensor
Post by Doone » Mon Jun 11, 2012 5:34 pm
Hello John, Allan spoke to you this morning. If you remove the engine tray underneath the engine, and look at the crankshaft pulley, you'll see the sensor to the bottom right.
