I removed the cylinder head from my Bongo a couple of months ago. The cylinder head was wrecked, massive crack on number two inlet valve. Only stopped by going further by the valve seat. Anyway, I digress. I am about to fit a refurbished cylinder head to the vehicle. Sadly, I have misplaced my notes of where the various vacuum pipes go. To add to this malady the tippex has washed off some of the pipes.
What I am looking for is this:-
Good diagrams/images of the various vacuum pipes in situation.
Fuel injection pipes. Still have my markings on them but not at the pump end. I am assuming that they will only correspond to the correct pump connection when married up to the injectors. However, knowing the pump connection to cylinder number would be useful.
Lastly, is there anyone living near Windsor that has a Bongo that I could pop around and view above. Would be helpful to have a "Bongo Buddy" for things such as this.
Vacuum pipes ec
Re: Vacuum pipes ec
Could this help for starters...? http://lushprojects.com/bongopartsmk2/c ... 1of02.html
Assuming you got diesel & the by the year in your forum name? That the van is an early model..
Re: Vacuum pipes ec
sorry for the delay (working too much) i will take some pics and draw a diagram and post it on here when i get a mo.
