Help: Front Headlight bulb replacement
fieldbarns
Post by fieldbarns » Sun May 13, 2012 9:44 am
New to Bongos and just about to set off on the road. How to I replace the front main headlamp bulb. Manage one of the rear light bulbs but can get access to the front ! Aaaaaargh
fieldbarns :?
Re: Help: Front Headlight bulb replacement
Post by Muzorewa » Sun May 13, 2012 9:57 am
It's a bit of a squeeze especially on the driver's side behind the battery but you need to remove the electrical connector at the back of the light (you have to squeeze the sides in as it's on a safety clip arrangement) then you can remove the big rubber grommet, release the spring clip and take the bulb out. A lot of this has to be done by feel as you can't really see what you're doing.
Bulbs are H4 (Halfords 472) :wink:
fieldbarns
Post by fieldbarns » Sun May 13, 2012 10:02 am
Thanks. Much appreciated. I started to go down that road but met some resistance so didnt want to be too heavy handed. Now I know I am on the right track I will try again.
sibot
Post by sibot » Sun May 13, 2012 10:46 am
It might help to do the nearside one first - I found there was more room there so you can see what you are doing, and use that to inform the blind fumblings on the offside...
fieldbarns
Post by fieldbarns » Sun May 13, 2012 2:46 pm
Thanks folks. After a lot of fumbling with the spring clip decided for some reason it wasnt going to budge so decided to take the grill off and the headlight out. Glad I did ! found that the spring clip was held in by the lip of a screw! I have reasonably slim fingers for a girlie but it was easier with the headlight out. Thanks for the advice on how to approach this - as a newby I was struggling.
cheers :D
