We bought our first bongo a week ago (2.5Ltr Diesel '95), drove it home, no problem. Drove it a day later and spotted the water temp climbing very quickly, only after a mile. Pulled in and popped the bonnet to find water spraying out from a pin prick at the bottom end of the top radiator hose (part 15-183: http://lushprojects.com/bongopartsmk2/c ... mgno=.html) - the dog-leg one
Managed to bandage the hole using a sanitary towel and some cord from the "Bongo toolkit" as a makeshift tourniquet and limped a mile home taking it very easy.
This weekend, drained and flushed the system and used all the fantastic advise given in the Mazda Bongo Bleeding YouTube vids.
See-sawed the system cold until no bubbles at the funnel end - all good.
Moved onto see-sawing the system with the engine running and straightaway there are huge kind of water eruptions at the funnel end. At no point do we let the expansion tank run dry or introduce any air at the funnel end and we just keep seesawing as it must just be trapped air right?
Well after about an hour of explosive seesawing (sounds painful) there is no change at the "angry funnel" end - surely this can't be air as if we turn the engine off and continue seesawing, its as slick as you like with no bubbles. I'm thinking there must be another fault somewhere as its so violent - almost like a heat swell or something working its way out as it doesn't look like air bubbles at all and nothing like it does in the YouTube vids.
Few more symptoms/clues hopefully..
- Rear heater blows hot air, front heater only cold
- Water temp, once up, stays at a constant 11 O'clock on the dial
- Radiator fans kick in when they should
- Bottom near-side radiator hose is continually cold
- If we switch off the engine, cap off the the bleed hose as per video instructions so as not to introduce any air, double check the water level is good in the expansion tank and replace its cap. Start the engine as normal, with a couple of mins we have coolant forcing its way out of the expansion tank overflow with crazy gurgling noises!?[/list]
Has anyone ever seen this? I'm quite anal when following instructions so don't believe I've missed a step and the detail in the vids is very good - any ideas people?
