Whatdyacallit?
Observer
Whatdyacallit?
Post by Observer » Sun May 06, 2012 3:44 pm
Hi, I'm trying to find a piece of connecting strip - it's like a series of metal tags in the form of a strip all joined together which would effectivley cause all of the connections in a surface mounted fuse block to become live from a single feed e.g. the LB. Does anyone know what I'm on about? I've seen it on a website but can't seem to find it now any help would be most appreciated.
My iPhone - My office
Re: Whatdyacallit?
Post by rita » Sun May 06, 2012 3:59 pm
Are you talking about a BUSBAR,
http://www.screwfix.com/p/mk-20-module- ... fAodxH9i1w
Re: Whatdyacallit?
Post by Simon Jones » Sun May 06, 2012 4:00 pm
Observer
Re: Whatdyacallit?
Post by Observer » Sun May 06, 2012 4:10 pm
Thank you both, I think the Screwfix job is what I meant I could snip off the bits that don't line up with the fuses amd then trim to length. =D> =D>
Re: Whatdyacallit?
Post by g8dhe » Sun May 06, 2012 4:21 pm
I think you'll find there meant for domestic Consumer units, rather than 12volt car fuses, the spacing is MUCH larger!
What make of fuse box are you using does it have a part number at all ?
Observer
Re: Whatdyacallit?
Post by Observer » Tue May 08, 2012 10:51 am
Oh well I'll have to think of something else - I haven't got the fuse block yet, I would have thought the 'busbar' would have done the job, I'm sure I saw one on an auto/marine web page. So, have you come across anything like it? The Screwfix pic gives no indication of size
Re: Whatdyacallit?
Post by teenmal » Tue May 08, 2012 11:08 am
Can you not use some suitable rated wire and make loops as required.
Cheers.
buddyh42
Re: Whatdyacallit?
Post by buddyh42 » Tue May 08, 2012 11:21 am
That'll Be The Day.........
'99 Silver V6 Moonfleet Conversion
Re: Whatdyacallit?
Post by g8dhe » Tue May 08, 2012 12:04 pm
There are various fuse holders on this site, some with common connections in place http://www.vehicle-wiring-products.eu/V ... lders1.php
Observer
Re: Whatdyacallit?
Post by Observer » Tue May 08, 2012 1:04 pm
Thanks all, just picked up a four way fuse block from Halfords and I've decided I can solder a bridge wire across the input terminals, add appropriate fuses and then run to the switch board and on to each appliance.
