Hello,
I have a manual 4wd Bongo running on standard steel 15" wheels and i want to put someting bigger on, is it OK to upgrade to 16 or 17's without causing any damage to the viscous coupling / 4wd components?
4WD WHEEL UPGRADE
Moderator: Ian
dingo1972
Re: 4WD WHEEL UPGRADE
Yes, as long as you keep the wheels and tyres the same size all round.
You can use this calculator to see what size tyres go with the relevant size wheels http://www.tyresave.co.uk/tyresize.html
dingo1972
Hi John,
Thanks for your prompt reply,
I was thinking about RX8 alloys as i think thy look nice on the bongo, just need to get 5 in case of a puncture then.
Any OEM direct replacement suggestions would be appreciated
Dean
Dean
Rx8 alloys are all 18". Tyres are quite rare in correct load rating and expensive. I have them on mine and considering dropping down an inch or two ans selling them. You can use a standard wheel for the spare as the have the same rolling radius
The Bongo Bodyshop - For all your Bongo Bodywork needs.
07584 134811
Advice is free.
07584 134811
Advice is free.
2manymadmonkeys
- Bongonaut
What's the lowest rating for a bongo 95 ?
