one roof motor
antman
one roof motor
Post by antman » Sat Apr 28, 2012 7:53 pm
Hi all
Just as my roof is nearing full extension is judders a little, is this due to the fact I can only see one motor on one side? Is this normal? Have lubricated all struts.
Re: one roof motor
Post by francophile1947 » Sat Apr 28, 2012 8:16 pm
It's normal, but can be helped by lubing the bottom runners, on both sides of each rail, with lithium grease.
antman
Re: one roof motor
Post by antman » Sat Apr 28, 2012 8:20 pm
There does seem to be some grease but not sure on both sides, it did wonder if the motor was not quite man enough, cheers
Re: one roof motor
Post by g8dhe » Sat Apr 28, 2012 8:37 pm
There are two motors, one each side, both the same place at the rear end of the top guide.
But yes they can judder a bit.
antman
Re: one roof motor
Post by antman » Sat Apr 28, 2012 9:05 pm
I'm sure I can only see one motor. I'll post a picture for you to advise :?
Re: one roof motor
Post by Simon Jones » Sat Apr 28, 2012 9:25 pm
They normally have a plastic cover over the motors, but sometimes they are missing so the motor is visible.
antman
Re: one roof motor
Post by antman » Sat Apr 28, 2012 10:16 pm
I'll take a look thanks for info
Much appreciated
