my Freda just got back from its MOT, failed on front brake pads and welding needs doing on some areas, ill do the pads and ive called Allan for the welding.
On the advisories it says my rear coil springs are corroded so i was looking at replacing them, ive looked on the inthernet and searched the forum here but cant seem to find anywhere to buy replacements. anyone know of a link or local place i can buy, im sire if i get stuck i can speak to Allan. any help much appreciated
steve
oh and my freda is a 1996 2.5 TD 2wd
where to buy Rear Coil Springs
stevearmitage
- The Great Pretender
Re: where to buy Rear Coil Springs
You could try looking at the springs to see the level of 'corrosion' then decide if it is just surface rust.
To infinity and beyond
