Best temporary security solutions?
Metalpetal
Post by Metalpetal » Fri Apr 13, 2012 12:21 pm
Another question - we will get an alarm fitted eventually, but for now funds are low after the bongo purchase! What's the best cheaper security alternative? A steering wheel lock? Or wheel clamp? (where do you get those and how much?)
The Bongo will be parked in our drive, but we're on a main road in a bit of an 'edgy' part of town and so I think we should do something!
Mp
winchman
Re: Best temporary security solutions?
Post by winchman » Fri Apr 13, 2012 1:03 pm
Cheapest is a hidden switch, one that cuts the supply to the lights and the other that cuts the starter motror curcuit, so if they hot wire it the starter wont turn, if they are clever and get it running then the lights still wont work.
Next best is a valve in the fuel line as it will start but cut out after a few mins and not restart unless they find the valve.
Remember they want to be in and out quickly
stefan442
Post by stefan442 » Fri Apr 13, 2012 1:12 pm
I bought a steering wheel lock from halfords as a stop gap! But i want to do the things mentioned as well, don't know where to start though!
Could get some cheap switches from work and just switch the live supply to the alt and lights And hide it somewhere
M 80NGO
Post by M 80NGO » Fri Apr 13, 2012 1:14 pm
If it's a petrol pull the king lead off of the distributor and coil, diesel then disconnect the battery, a cat 2 immobilizer can be supplied n fitted for around £120, steering wheel locks are good and can be had at a good price off of e-bay, also you can add a dummy alarm led to the dash and get some clifford / cobra stickers off of e-bay to give the image of a protected vehicle.
Post by g8dhe » Fri Apr 13, 2012 1:16 pm
There is a Club Factsheet covering this here http://www.igmaynard.co.uk/bongo/member ... switch.pdf
stefan442
Post by stefan442 » Fri Apr 13, 2012 1:26 pm
g8dhe wrote:There is a Club Factsheet covering this here http://www.igmaynard.co.uk/bongo/member ... switch.pdf
Why thank you sir :D I knew becoming a member had its perks :D
M 80NGO wrote:If it's a petrol pull the king lead off of the distributor and coil, diesel then disconnect the battery, a cat 2 immobilizer can be supplied n fitted for around £120, steering wheel locks are good and can be had at a good price off of e-bay, also you can add a dummy alarm led to the dash and get some clifford / cobra stickers off of e-bay to give the image of a protected vehicle.
Have a led in le post, hopefully will arrive tomorrow!
cat 2 alarm might be a good shout for peace of mind, and hopefully bring down insurance. Maybe.
dandemann8
Post by dandemann8 » Fri Apr 13, 2012 1:31 pm
Or do as the Ossie's do and put a bloody big snake on the dashboard :shock: :lol: :lol: :lol:
Bongo no more........... ;-(
Metalpetal
Post by Metalpetal » Fri Apr 13, 2012 1:38 pm
Thanks everyone, and for pointing me at the fact sheet (it's a 2.5 diesel btw). I shall have a look on eBay - I've got a bit of time on my hands as I had a tooth extracted today so am resting up and feeling a bit sorry for myself :| Knowing we'll have our Bongo in 3 days is helping to cheer me up though!! :D
321Away
Post by 321Away » Fri Apr 13, 2012 3:42 pm
£120 for a cat2!! shop around you'll get em for around the £90 mark
Julian
Post by Bob » Fri Apr 13, 2012 4:09 pm
Disklok for about £40 on line helps, visual too.
M 80NGO
Post by M 80NGO » Fri Apr 13, 2012 5:21 pm
Julian
Yeah you probably will, but for a decent one expect to pay around £120 fitted :wink:
Dr Fingers
Post by Dr Fingers » Fri Apr 13, 2012 5:28 pm
Went for this..
http://www.ebay.co.uk/itm/310290989621? ... 1439.l2649
Pricey (there are cheaper ones) but very solid. Same as you, parked in drive with no Cat alarm (yet), but one of these looks seriously off-putting! Much easier to deal with than hidden switches etc.
Derek
ELZE
Post by ELZE » Fri Apr 13, 2012 7:05 pm
Best anti theft device in the business and only costs a tenner. No power no theft. Hard to spot in the daylight never mind the dark. I used these on the Landrovers I owned with much success.!
stefan442
Post by stefan442 » Fri Apr 13, 2012 7:16 pm
ELZE wrote:Best anti theft device in the business and only costs a tenner. No power no theft. Hard to spot in the daylight never mind the dark. I used these on the Landrovers I owned with much success.!
EBay link?
Fitted a switch on the fuel solenoid earlier. Hidden out of the way, works a treat! :)
Mickymouse
Post by Mickymouse » Fri Apr 13, 2012 7:19 pm
Hi Elze
What are they and who sells them?
Mick
White 1996 P.reg SGL3 2.5D AFT Side Conversion
