Air-con system gas capacity???
Bongo??
Post by Bongo?? » Thu Apr 12, 2012 9:21 pm
As title really,how much gas does the air-con system take??
TA MUCH.........................
Year 2000 V6
markoos
Re: Air-con system gas capacity???
Post by markoos » Thu Apr 12, 2012 10:05 pm
I believe its 950 gramms of R134a, i would weight the refrigerant in and check the suction and discharge pressure are stable at around 3000 rpm. I would also check theres no frost back on the suction line to the compressor.
Cheers Mark
Post by Simon Jones » Thu Apr 12, 2012 11:35 pm
There is a fact sheet that may help. I printed it off and gave it to the guys who regassed mine: http://www.igmaynard.co.uk/bongo/member ... aircon.pdf
Bongo??
Post by Bongo?? » Fri Apr 13, 2012 8:32 pm
Simon Jones wrote:There is a fact sheet that may help. I printed it off and gave it to the guys who regassed mine: http://www.igmaynard.co.uk/bongo/member ... aircon.pdf
Hello Simon...
I`m prompted for a username and password when i click on this link,tried my PW for Bongo Fury but it won`t let me in....
Any idea`s?????? :roll: :roll: :roll: :roll:
Year 2000 V6
longhaul8
Post by longhaul8 » Fri Apr 13, 2012 8:37 pm
Are you a member ? if not you cannot access the fact sheets.
If you are a member you should have had a password emailed to you.
Post by g8dhe » Fri Apr 13, 2012 8:51 pm
You need to be a Club member not just a forum member, see the link at the very top in red!
Bongo??
Post by Bongo?? » Fri Apr 13, 2012 9:05 pm
g8dhe wrote:You need to be a Club member not just a forum member, see the link at the very top in red!
That`ll be why then,i`m only a forum member,will look into full membership now!!!! :D :D
Year 2000 V6
