Moderator: Ian
Bongo??
Post
by Bongo?? » Sun Apr 08, 2012 9:10 pm
Hi all.
What do you folks reccommend as the best combination for aftermarket alloys and tyres.
Bearing in mind that the Bongo comes with different size tyres front and back do you make them all the same??
I was looking at either 16" or 17".
Do any other Mazda alloys go straight on??
Thanks in advance...
Year 2000 V6
chipvan
Post
by chipvan » Sun Apr 08, 2012 9:20 pm
Your wheels pretty nice from here!
Bongo??
Post
by Bongo?? » Sun Apr 08, 2012 9:30 pm
chipvan wrote:Your wheels pretty nice from here!
They are from a distance,they are chrome but are starting to corrode.
Year 2000 V6
chipvan
Post
by chipvan » Sun Apr 08, 2012 10:15 pm
would it be cheaper to get them re sprayed?? ..
8etty 8ongo
- Tribal Elder
Post
by 8etty 8ongo » Sun Apr 08, 2012 11:47 pm
hi, i have just bought some 16" mazda 6 alloys which wheelquick have assured me will fit. hopefully be on this week when my son has finished refurbishing them
bongodonkey
- Tribal Elder
Post
by bongodonkey » Mon Apr 09, 2012 8:24 pm
It all depends on your model.
All 2WD models can have any suited size alloys to run on them. I run some RX8 alloys with Accelera 225/R18/55 tyres on mine.
Lush!!!
There are some right bargins to be had on ebay (RX8 alloys etc), and some cracking online sites to purchase decent tyres as well.
However, if you have a 4WD model you have to be really careful what you put on the bongo, or you will end up burning out the diff's.
The fine gents at Wheel Quick (the 2 Mikes) are a wealth of information and will point you in the right direction.
Oz, Sam & the girls | 2001 V6 AFT | LPG | 321Away F/S/C | A Bongo called OLIVE
Post
by Simon Jones » Mon Apr 09, 2012 10:25 pm
Don't forget, the size of the wheel rim is not critical, but it's the rolling circumference of the tyres that matters. Whether 2WD or 4WD you should aim to go for 4 identical sizes (with a suitable spare to match). That will give you complete flexibility to swap front to rear (& vice versa) to spread the tyre wear and you won't have a problem if you get a puncture.
Bongo??
Post
by Bongo?? » Tue Apr 10, 2012 12:04 am
Are these specs OK for a MY2000 V6???
Offset: 40
Tyre Type: All-Weather
Rim Diameter: 16
Rim Width: 6.5J
Aspect Ratio: 55
Number of Studs: 5
Stud Diameter: 114
Tyre Width: 205
Metal Type: Aluminium
Premium Performance 205/55/16 Tyres.
THANKS....................
Year 2000 V6
Post
by Northern Bongolow » Tue Apr 10, 2012 12:15 am
premium tyres but with what load rating ?? may have a high speed rating but you need to check the weight/load rating.
Bongo??
Post
by Bongo?? » Tue Apr 10, 2012 12:25 am
Northern Bongolow wrote:premium tyres but with what load rating ?? may have a high speed rating but you need to check the weight/load rating.
What is the load rating on the Bongo?
Year 2000 V6
scanner
Post
by scanner » Tue Apr 10, 2012 4:28 am
Bongo?? wrote:Northern Bongolow wrote:premium tyres but with what load rating ?? may have a high speed rating but you need to check the weight/load rating.
It should be on the ratings plate inside the driver's door opening.
It (usually) states front 92 (for 195/70-15) and rear 96 (for 215/65-15) - those are the minimum load index figures that should be used.
Post
by Simon Jones » Tue Apr 10, 2012 7:58 am
Remember to check the size of the centre bore of the rim. Ideally it should be 67.1 mm, but you can go larger with the use of 'spigot rings'. See this thread for a cautionary tale of replacement wheels which would not fit:
http://www.igmaynard.co.uk/bongo/forum/ ... pigot+ring
