fuel gauge reading permanamtley full after new earth
Deebee
Post by Deebee » Thu Apr 05, 2012 8:28 pm
Hi, Ive got a problem with my 95 bongo 2.5td, the fuel gauge stopped working which i think was the earth. i fitted anew earth to the plug (there was nothing wrong with the sendor/sendor earth) but now the gauge reads full all of the time??
any ideas?
Re: fuel gauge reading permanamtley full after new earth
Post by francophile1947 » Thu Apr 05, 2012 9:28 pm
Yes - go to Photobucket and make your photos 640x480 :lol: :lol:
Sorry, no idea about your problem, but Geoff will probably be along soon 8)
Darkstar
Post by Darkstar » Thu Apr 05, 2012 10:16 pm
did you earth the positive by mistake?
that would give you a full tank reading
Got a Bongo for the Wife, Best trade-in ever
Post by g8dhe » Thu Apr 05, 2012 10:31 pm
See this post for a close up of the pin that needs the earth connecting to it http://www.igmaynard.co.uk/bongo/forum/ ... 76#p491876
Deebee
Post by Deebee » Thu Apr 05, 2012 10:40 pm
That's the biggest photo the forum would let me upload.
And the earth is from the the green (I think) wire. It's the one with zero volts anyway.
daveblueozzie
Post by daveblueozzie » Fri Apr 06, 2012 12:29 am
Deebee wrote:That's the biggest photo the forum would let me upload.
As far as mine and a couple of others that i have done its always to the black wire.
Lost without my Bongo.
321Away
Post by 321Away » Fri Apr 06, 2012 9:08 am
just earth the tank itself, easiest way,as they said the fuel level sender is a crude earth referenced rheostat and if you earth the wrong (signal)wire, it'll just read full
Julian
Post by g8dhe » Fri Apr 06, 2012 10:08 am
That's the problem then the Earth wire is BLACK and the signal is Light Green with Yellow stripe;
C1-04 is the sender;
Post by francophile1947 » Fri Apr 06, 2012 11:50 am
Puzzling, as your photo is well within the limits :? - did you read this http://www.igmaynard.co.uk/bongo/forum/ ... =42&t=9285
Looks like your earthing problem is sorted 8)
winchman
Post by winchman » Sat Apr 07, 2012 5:11 pm
Now when I purchased Bertie the old owner told me he had tried the earth and the sender was no good so I bought another from a scrappy.
When we tested this we found high resistance in the sender due to slight corrsion in the joints, so we removed the bolted on plastic bit from the bottom and fitted a new earth wire to the bolt, drilled a hole in the top mounting plate, put a nut and bolt through it with a EPDM rubber joint either side ( yes its fine with diesel) we then attached the wire to the bolt, put the lot in the tank and run the new earth from the body to this bolt.
If you measure the resistance from the top mountig plate top the bolt that secures the white plastic bit on to pick up pipe you should have almost zero, if not the joints are corroded and you need to fit this little extra earth wireto keep it accurate
Oh I assume the float arm isnt bent as this can also give a false reading
Deebee
Post by Deebee » Wed Apr 11, 2012 4:52 pm
Ok thanks for all the help guys. Just to fill you in, a new earth to the black plug on top didn't fix it, and a new earth from the soldered joint on the fuel sender to the plug didn't fix it either. BUT hurrah a new earth from the tank lid to the vehicle body had it working dandy.
Thanks for your help :D
