chsnging type of veg/flower oil
- Junior Bongonaut
hello all, i have been running on a 30% rapeseed mix but it is now £1.29 lt , can i run on sunflower? as its only £10.00 for 10lt at tesco. new milton hants.
Re: chsnging type of veg/flower oil
Yes, but it's slightly thicker than rapeseed oil, so you may only get away with using a little less in the tank. I only found it a problem on colder mornings, but it was fine after the engine warmed up.
- rhino-wayne
Have ran the Bongo on Sunflower oil/diesel mix no problems, but have found a cheaper rapeseed oil (20ltr) at an "Asian" supermarket........keep hunting!
