fog lights dont work??
8etty 8ongo
Post by 8etty 8ongo » Sun Apr 01, 2012 6:12 pm
hi everyone, trying to get the bongo ready for the up and coming mot and so oh had a look at the fog lights today as none of them work and we cant work them out. apparently theres just loads of wires and he thinks its something to do with an alarm that was fitted that we had turned off due to some problem or other. anyway so im wondering if anyone can recommend somewhere i can take it for someone to have a look at.
any help appreciated :) :)
Re: fog lights dont work??
Post by francophile1947 » Sun Apr 01, 2012 7:50 pm
Have you turned your side lights on? Fogs sometimes don't work until you have.
8etty 8ongo
Post by 8etty 8ongo » Sun Apr 01, 2012 8:31 pm
francophile1947 wrote:Have you turned your side lights on? Fogs sometimes don't work until you have.
yeh, tried that and nothing, neither the front or back work. i need someone who knows electrics to look at it. will this be just any garage or do i have to go to a specialist?
having a love hate relationship with the bongo at the mo :roll: :roll: :roll:
Lotustuart
Post by Lotustuart » Sun Apr 01, 2012 9:40 pm
Have you looked at the little black connection blocks? My fog lights didn't work when I picked her up, when I unplugged the black connectors I found a lot of blue dust! ie .the copper connectors had disintegrated. I stripped the wires back and put in new connections and I have seen the light! 5 mins work, job done!
8etty 8ongo
Post by 8etty 8ongo » Mon Apr 02, 2012 7:39 am
Lotustuart wrote:Have you looked at the little black connection blocks? My fog lights didn't work when I picked her up, when I unplugged the black connectors I found a lot of blue dust! ie .the copper connectors had disintegrated. I stripped the wires back and put in new connections and I have seen the light! 5 mins work, job done!
thanks, i think the problem is there is too many wires and an alarm has been fitted in the past and then disconnected because it kept locking us out of the car :lol: :lol: :lol:
....and we're not techie minded so dont know where to start :?: :|
with that in mind, is there anyone local who knows this stuff that would have a go at fixing it for a price? [-o< [-o< [-o<
Post by teenmal » Mon Apr 02, 2012 9:29 am
8etty 8ongo wrote:hi everyone, trying to get the bongo ready for the up and coming mot and so oh had a look at the fog lights today as none of them work and we cant work them out. apparently theres just loads of wires and he thinks its something to do with an alarm that was fitted that we had turned off due to some problem or other. anyway so im wondering if anyone can recommend somewhere i can take it for someone to have a look at.
if you are also talking about the front fogs,they are not part of the MOT.You only need the rear fog lamp/s working for the MOT.
Cheers.
8etty 8ongo
Post by 8etty 8ongo » Mon Apr 02, 2012 12:17 pm
Cheers.
hi, thanks, neither the front or back ones work. would the wires for the back ones be at the front as well though?
Post by francophile1947 » Mon Apr 02, 2012 12:27 pm
8etty 8ongo wrote: would the wires for the back ones be at the front as well though?
No - it should be through a separate switch.
321Away
Post by 321Away » Mon Apr 02, 2012 12:43 pm
relay under the bonnet against passenger inner wing, usually the further most forward. are you sure your switch is plugged in behind the dash?
Julian
Post by Simon Jones » Mon Apr 02, 2012 1:19 pm
Does the tell-tale light on the switch come on when you turn it on? That will at least indicate you have power at that end. Have you tried changing the bulb in the rear light (assuming you have a seperate foglight mounted in / under the bumper).
If you're stuck, try DBO or Wheelquick.
8etty 8ongo
Post by 8etty 8ongo » Mon Apr 02, 2012 2:19 pm
Simon Jones wrote:Does the tell-tale light on the switch come on when you turn it on? That will at least indicate you have power at that end. Have you tried changing the bulb in the rear light (assuming you have a seperate foglight mounted in / under the bumper).
hi, thats a good point actually. since my husband fiddled with it yesterday, there is now a red light showing fogs on the dash. before that there was nothing so maybe we should try a new bulb?
jaylee
Post by jaylee » Mon Apr 02, 2012 2:58 pm
You sure the alarm has not been set to a "passive arming" setting...? :-k
8etty 8ongo
Post by 8etty 8ongo » Mon Apr 02, 2012 10:20 pm
really have no idea, my son had a look and hes no idea either and hes generally pretty good around cars..
jaylee
Post by jaylee » Tue Apr 03, 2012 12:11 am
8etty 8ongo wrote:since my husband fiddled with it yesterday, there is now a red light showing fogs on the dash. before that there was nothing so maybe we should try a new bulb?
OK, back to the fogs... Were the dash lights & "tail lights" working during this anomaly...? :-k
8etty 8ongo
Post by 8etty 8ongo » Tue Apr 03, 2012 8:37 am
:lol: :lol: =D>
im really not sure what was working... and the fog light on the dash doesnt come on now. my son replaced the dangly with a flush fog light last month but that didnt have anything to do with it becasue he just swapped them over. need an expert to look at it me thinks
