Front brake discs 2.5 D
vanvliet
Post by vanvliet » Tue Mar 27, 2012 8:29 am
Does anyone know the spec /size of the front discs? Are they vented - 5 holes 274 Diameter 51mm height 28/26 max/min thickness as on the Mazda MPV ? I know that the calipers are not the MPV ones but the pads are .
EBC do not list the Bongo
Origo bio stove - no Bongo!
Driver+Passengers
Re: Front brake discs 2.5 D
Post by Driver+Passengers » Tue Mar 27, 2012 8:53 am
Not sure about sizes, but here's a part number: M206067.
Image Image
Post by teenmal » Tue Mar 27, 2012 12:39 pm
Hi,does this help,
Brake Disc Thickness [mm]28,0Brake Disc TypeVented
Centering Diameter [mm]72Diameter [mm]276
Height [mm]58Hole Arrangement / Number05/05
Minimum Thickness [mm]26Pitch Circle Ø [mm]114,3
Supplementary Article/Supplementary Info 2without wheel hub, without wheel studsWeight [kg]8,15
Fitting PositionFrontFitted Quantity2
vanvliet
Post by vanvliet » Tue Mar 27, 2012 12:56 pm
Thanks for the advice
