Gear box issue I'm told it's the TCM / ECU / Computer
merrlyn
Post by merrlyn » Tue Mar 20, 2012 6:23 pm
I own a W plate Bongo with gear box issues :oops: It's been dropping out of 1st gear at around 1500 revs and horribly crashing back in with the hold light eventuallycoming on and then getting stuck in 3rd.
A highly recomended local auto gearbox speicalist has been looking at it. His tester said that there was a fault on solienoid 2, which was duely ordered and replaced, but has not cured the problem. Upon further investigation swapping the other solienoids and testing has shown no difference so he called his electrical specialist in to check the wireing etc. He has found no faults either and they now beleive the fault to lie with the "computer" which controls the gearbox and body. I have no experience in this area at all but I'm told that this was formally called the ECU and is now the TCM or transmissioon control unit.
However, trying to locate this unit for a year 2000 Bongo is proving very difficult. If anyone has any advice, or has had a similar problem they've solved I'd be grateful to hear from you as my beloved Bongo has now been off the road for opver 3 weeks! The gearbox has already been flushed and new oil etc installed but ths hasn't madeany difference.
your hopefully,
Simon.
willgant
Re: Gear box issue I'm told it's the TCM / ECU / Computer
Post by willgant » Tue Aug 15, 2017 1:15 pm
Hi Simon,
I am having a very similar problem with my V reg Bongo. it's now been in the garage for 13 weeks!
Have you had any good news for yours yet?
I would be really grateful to hear some good news right now!
Thanks and good luck
Will
Post by g8dhe » Tue Aug 15, 2017 1:53 pm
Have you tried George at Bongo Spares http://www.bongospares.co.uk/ ?
Post by mikeonb4c » Tue Aug 15, 2017 2:57 pm
Where are you based Simon?
Post by rita » Tue Aug 15, 2017 3:55 pm
willgant wrote:Hi Simon,
Will
I would hope so , that post was over 5 Years ago. Tue Mar 20, 2012
Post by mikeonb4c » Tue Aug 15, 2017 7:38 pm
Doh! #-o #-o #-o
