recovery to plmouth
recovery to plmouth
Hi does any of you know how much it would cost me to transport my Bongo from birmingham to plymouth. As it has been to two garages in Birmingham and they could not find what is wrong. I have so I think that I should get it to Allans services in Plymouth as from getting information on this site he seems to know what is doing. Thanks John
Re: recovery to plmouth
Many thanks for the vote of confidence, although we are a long way from you.
Allan is out tonight, so I can't ask him for advice.
But it's worth checking to see if there are any fault codes before you do anything else. If there are, it might help to tell you what's going on.
Do you know how to do that? http://www.igmaynard.co.uk/bongo/forum/ ... 15#p528891
And there is a factsheet in the members area.
If you can't do this, I wonder if there's a member in your area who could check for you, to see if any codes are stored?
Allan is good but even he would I'm sure admit there are one or two others just as good and much nearer to you. Ian Taylor in Stoke and Gerry at Discount Trucks in Newbury are two that spring to mind. Paul at LPG Imports in Coventry and Julian at 321Away in Bracknell are two others. And could Phil at JAL in Worcester put you on to whoever does his work?
