Rev Counter sensor location *Dont delete*
froghandler
Post by froghandler » Thu Mar 15, 2012 4:14 pm
Hello
Could someone point me in the right direction to locate the rev counter sensor (NE sensor?) please on a 2.5 diesel.
Thank you. :D
Re: Rev Counter sensor location
Post by g8dhe » Thu Mar 15, 2012 8:43 pm
See the diagrams referred to in this thread the exact position depends on the version of the vehicle, some times called a Pulse Generator and in later versions referred to as the NE Sensor
http://www.igmaynard.co.uk/bongo/forum/ ... 07#p543807
321Away
Post by 321Away » Sat Mar 17, 2012 10:38 am
early or late shape? early is drivers side just in front of fuel pump, later dhapes are front of engine behind crank pulley
Julian
Rhinoman
Re: Rev Counter sensor location *Dont delete*
Post by Rhinoman » Tue Mar 20, 2012 12:40 pm
Sorry to hijacy but while we're on the subject do you know if its a VR sensor or a Hall Effect sensor? I'm guessing VR as they call it NE. How many teeth are there?
1995 Ford Freda, 2.5TD, auto, AFT, side conversion.
froghandler
Post by froghandler » Tue Mar 20, 2012 9:33 pm
Thanks Julian - it's a 2003 model - will have a look when I'm off work.
Very occasionally the rev counter stops working but I don't get any other symptoms like the hold light flashing.
It may be a dodgy connection as usually a good thump on top of the dash gets it working again, but wanted to check the sensor out.
