ATF top up on V6 *DON'T DELETE*
Bainsy
Post by Bainsy » Tue Mar 13, 2012 1:08 pm
Have now found ATF dip stick under driver's seat along with engine oil filler cap. When ATF needs topping up where is the filler cap?
Nigel
New Shape White over Silver V6 LPG JAL Side Conversion Mushroom Roof
wonkanoby
Re: ATF top up on V6
Post by wonkanoby » Tue Mar 13, 2012 1:09 pm
you use a small funnel and pour down the dipstick tube
dave_aber
Post by dave_aber » Tue Mar 13, 2012 1:10 pm
You fill the ATF down the dipstick hole.
Make sure you have checked the level correctly, in drive, or you will have an incorrect reading.
Image...Image
Post by g8dhe » Tue Mar 13, 2012 1:11 pm
There isn't a filler cap :lol: :!: :!: :!:
See here for the details .... http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=30096
Lorna - Would it be worth making the above a *Do Not Delete * ??
Re: ATF top up on V6 *DON'T DELETE*
Post by Doone » Tue Mar 13, 2012 3:29 pm
That's a good idea, even tho we rarely delete in Techie, because it shows the post is being linked to, or is very handy.
I've now made it into a FAQ along with Kirstys post on how to change the ATF. And there's a downloadable factsheet in the members area.
http://www.igmaynard.co.uk/bongo/forum/ ... 43&t=54458
TheHillsAreCalling
Post by TheHillsAreCalling » Tue Oct 18, 2016 9:52 am
Hi there... The link to the factsheet is broken - I get a 404 when trying it. Would it be possible to reinstate it please?
My Auto transmission is slipping when changing gears and I suspect it might be the ATF level so the factsheet would be really useful.
mikeWalsall
Post by mikeWalsall » Tue Oct 18, 2016 10:07 am
Only paid up members and not Forum users can access the members section / tutorials .. but the ... http://igmaynard.co.uk/bongo/forum/view ... =3&t=30096 .. link is working for me and I am just a Forum user ..!!
But this is a basic explanation of location / method to check the Dexron 3 fluid ..
As the fluid is topped up down the dip stick tube you will need a funnel .. I use one like this ...
Ideally the fluid should look a transparent cherry red ... if it's a mucky brown / smells of burnt toast it's due for a change ..
